Group: DynoMotion Message: 5114 From: mattbsemail Date: 5/30/2012
Subject: It's hooked up Kmotion installed board not detected?
Plz help. I am having a bit of trouble. I have tried both with and without the power supply. The first way I hooked it up was via the USB port and the J3 jumper in place. It was not recognized then I pulled the J3 jumper and plugged into the power supply and still not recognized. I am running windows 7 64 Bit. The computer makes sound when the USB is plugged in. The leds on the board do the flash to solid thing but KMotion says disconnected at the top left of the window. After I click version I get message Cannot connect to KMotion board#0
Group: DynoMotion Message: 5115 From: mattbsemail Date: 5/30/2012
Subject: Re: It's hooked up Kmotion installed board not detected?
Ok so I clicked my hidden icons, clicked safely remove hardware, then clicked open devices and printers, KMotion is under the unspecified tab. I click properties, then change settings, update driver, browse my computer, C, KMotion429, and this is where I am stuck...
Group: DynoMotion Message: 5116 From: mattbsemail Date: 5/30/2012
Ok so I realized I could just click on the KMotion429 folder and click ok. All is well. False alarm.
